Factory reset CT002 - HowTo? - Nederlands onderaan ;-)
Hi,
I recently stepped into the world of Marstek.
We have a 3-phase system in BE, and we have installed 3x Venus 3E.
We also have a CT002.
What is my issue?
Upon first installing everything, things looked quite ok.
From the start it was my goal to incorporate with Home Assistant, but I wanted to first get things working out of the box, in order to be able to familiarise myself with the Venus E as it is sold by Marstek without any modifications.
During initialisation of the CT002, the Marstek app asked if it could add “devices” to a group…
Not knowing what is the purpose or value of a group, I allowed this.
Then later on, I noticed, that in device view, I had 4 items, the 3 batteries + the cT002, but in group view, I only had 2 batteries???
I also noticed that, at least to me, it seemed like two batteries were working in tandem, while the third battery seemed to work the opposite way… Could this have something to do with it not being a member of the group?
I tried all things to add the non-group member battery to the group, but nothing worked.
I then, from within the Marstek app, filed a help request, and got an answer the next morning, so surprisingly quick.
The message requested me to do a firmware update of the CT002.
Now I’m not 1000% sure, but I believe they pushed a downgrade of the firmware. From EMS 124 → 119.
After the flashing of the firmware, the CT002 only shows the bottom blue LED, and not the green LED anymore.
And the CT002 is totally unreachable.
I have tried all kinds of sequences of powering off and on, in the mean time waiting etc but nothing helps.
So here’s my question:
Can anyone help with forcing the CT002 into firmware update mode? Or to inititiate a CT002 factory reset?
P.S. I have not yet gone the Home Assistant path.
Hoi,
Recent in de wereld van Marstek gestapt.
Wij hebben een 3-fase systeem in BE, en we hebben 3 Venus E batterijen geinstalleerd, 1 per fase.
We hebben ook een CT002
Wat is mijn probleem?
Na de initiële installatie, leek alles vrij OK.
Van bij aanvang was het mijn bedoeling het geheel te integreren in onze Home Assistant omgeving.
Echter wilde ik in eerste instantie vertrouwd geraken met het Marstek systeem, zoals het is out of the box en zonder niet officiële ingrepen.
Tijdens de installatie van de CT002, vroeg de Marstek app of de “apparaten” aan een groep mochten toegevoegd worden..
Zonder goed te weten wat dit betekende, heb ik hier ja op geantwoord.
Later viel het mij op, dat in “apparaat overzicht” ik 4 items had, de 3 batterijen + de CT002, echter in het “groeps overzicht”, zag ik slechts 2 van de 3 batterijen???
Het viel me ook op, althans zo leek het toch voor mij, dat 2 batterijen in tandem werkten , terwijl de 3de batterij in tegengestelde richting leek te werken…
Zou dit iets kunnen te maken hebben met het gegeven dat de 3de batterij geen lid was van de “groep”?
Ik heb alle mogelijke dingen geprobeerd om de niet-groepslid batterij toe te voegen aan de “groep” echter dit kreeg ik niet voor elkaar.
Ik heb toen vanuit de Marstek app een help aanvraag gedaan naar Marstek, en tegen alle verwachtingen ontving ik de volgende ochtend een antwoord.
Marstek support vroeg me een firmware update uit te voeren van de CT002.
Nu ben ik er niet 1000% zeker van, maar volgens mij hebben ze een firmware downgrade gepushed. Van EMS 124 → 119.
Na het flashen van de firmware, licht enkel de onderste blauwe LED op, de groene LED blijft ALTIJD uit.
En.. de CT002 is nu totaal onbereikbaar..
Ik heb vervolgens alle mogelijke opstart volgordes uitgeprobeerd, in de tussentijd wachten etc, maar niets helpt. De CT002 blijft quasi dood.
Dus hier is mijn vraag:
Kan iemand mij helpen met het forceren van de CT002 in firmware update mode?
Of een factory reset te initiëren?
P.S. Ik heb het Home Assistant pad nog niet bewandeld!
Bedankt!
Erwin
Nederlands is prima hoor;). Alles is hier in het Nederlands!
Heb even voor je opgezocht hoe de CT002 gereset moet worden en er zou gewoon een knopje op moeten zitten?
Zie afbeelding hieronder, nummer 4 is de reset button (lang inhouden neen ik aan).
Hoi Ruud,
Bedankt voor de reactie;
Het was mij al eerder opgevallen dat er blijkbaar verschillende versies van de CT002 bestaan.
Degen die jij toont heeft een klein antennetje, en ik zie ook op het linker plaatje dat deze een RJ45 heeft.
Mijn CT002 heeft dat niet. Op het boekje staat: Marstek CT002 - TPM-100CTW.
Heb je mogelijk een link naar waar je deze screenshot vandaan hebt?
@ipanini Hmm, die heb ik niet. Ik had deze van de officiële Marstek-website, maar zie jouw versie er niet bij staan. Heb je al contact gehad met de shop waar je 'm gekocht hebt?
Ik ben in ieder geval benieuwd naar het antwoord;
